Is this a good turbo?
Old Dec 24, 2007 | 02:17 PM
Hotsawce97's Avatar
Default Is this a good turbo?
http://cgi.ebay.com/ebaymotors/T3-T4...spagenameZWDVW
[align=left] [/align]
Old Dec 24, 2007 | 02:58 PM
riceburner700's Avatar
Default RE: Is this a good turbo?
anything under 1200 that isnt a greddy kit is gonna fail on you. save your money and either piece your own kit together with decent parts look for a cheap greddy kit with an intercooler for about 1200 bucks and it will be reliable
Old Dec 24, 2007 | 04:39 PM
gsumano's Avatar
ORIGINAL: riceburner700
If it's too shinny and cost under one grand it is most likely a piece of crap
Old Dec 25, 2007 | 07:51 AM
ic892003's Avatar
yea, dont get it, if your tight on money and cant buy a full trubo kit then piece one together yourself, itll be cheaper
Old Dec 25, 2007 | 08:58 AM
kokasian's Avatar
I like how everything is "super" lol. The turbo might be ok if you rebuild it with garret internals but the manifold will most likely crack. Some people have good luck with cheapo kits tho
Old Dec 29, 2007 | 05:32 PM
boombringer's Avatar
ORIGINAL: kokasian
So if you get a good manifold you should be ok? Or will other things crap out on you.
Old Dec 29, 2007 | 05:42 PM
Mr Mobsta Man's Avatar
Why chance it, seriously. Do it right and rest at ease that something isn't going to fail leaving you stranded witha blown engine. Where does the money you saved from buying a cheap kit go? Into a replacement engine. That would be the worse case sienario like ifthe turbo blades get loose and start grinding metal off of the housing and blowing it into your engine... or the wastegate fails to open causing you to hit like 25psi, probably really fun for like 2 seconds until your rods can't take it anymore.
Old Jan 3, 2008 | 05:31 PM
SamTay's Avatar
i would love to get my own turbocharger from spooledmotorsports.com and piece it together myself, but, sadly, im not experienced enough and i dont know everything i need, or if it would fit, etc etc. i think if i did it i would end up buying stuff that didtn fit and eff everything up. =( i thought i knew most of it, but then this guy on yahoo answers totally blew me out of the water and told me i needed way more stuff
Old Jan 4, 2008 | 08:27 AM
Buy the book called Maximum Boost, do google searches, read the stickys on this forum and others about boost, look in our diy section and there is a diy on piecing together a kit. You just have to learn, none of us started out knowing all this stuff either. We had to learn just like you will need to. That is the reason most of us have civics, we build fast cars ourselves not buy fast cars.
GeekNinja17
Nov 4, 2011 01:51 PM
edmaxx
33
Jun 28, 2010 03:27 PM
JAMfire
Jan 21, 2008 12:12 PM
cderalow
May 4, 2007 10:26 PM
jaidedeye
Apr 21, 2005 01:12 PM
