Hondata with turbo??????
when you turbo charge a car, thats when you need Hondata. Hondata is a program used to program your OBD1 ECU exactly how you need it to, you can adjust air/fuel ratios, timing, spark and various other things needed to make your car run its best. I think Hondata is one of the more expensive tuning programs out there since it can do so much, Crome, Neptune and Uberdata are a few other programs that are used for tuning Honda ECUs.
well i couldnt tell ya then, i'm just telling you waht Hondata is, idk what program you should use for your 06/07 Civic, research man, google, look around Honda forums, or there might be a more knowledgable person on here in a little while
ORIGINAL: bigfank3
If you look at the hondada websit though it says that they have not tested it on the 06/07 civics with forced induction?
silvic00
Mar 8, 2005 02:48 PM
