JPNolan's Project turbo EF is no more.
Old Jun 25, 2008 | 04:06 PM
didder's Avatar
Default RE: JPNolan&\\;amp\\\\\\;amp\\\\\\;rsquo\\\\\\;s Project EF (56k gtfo)
did you fix the overheating problem??
your new problem sounds like a fuel problem, check the fuel pump... my car did that and cured itself, but my problem was a glitch in my ecu i think..
what are you tuned on? PLEASE TELL ME YOUR TUNED
Old Jun 25, 2008 | 07:08 PM
Mr Mobsta Man's Avatar
Don't 4th gens have big problems with their main relays? That might be your problem.
Old Jun 25, 2008 | 09:46 PM
jpnolan's Avatar
not even boosted yet so im not tuned. but in the end had to tow it to my mechanic who will diagnos the problem for free from there im going to probably fix it. when i spoke to him before the car got their he said he thought it might be the fuel pump so well see tmmr. This turbo is going to take much longer than expected i by far am not making enough money but hopefully within the next year ill have it done.
Old Jun 26, 2008 | 12:38 AM
Hailchristian's Avatar
definitly sounds like the main relay.
Old Jun 26, 2008 | 09:18 AM
jpnolan's Avatar
going to drop off the key with the mechanic in a few minutes let him tell me the problem then fix it myself
Old Jun 26, 2008 | 04:27 PM
GReddy_Civic's Avatar
Snail'n Admin
Also..I noticed your conversion harness problem in your list...I think you told me you had a y8 swapped in there (didnt look for a vtak solenoid in the pic) but if it is swapped...you should have an obd2 ecu unless it was already converted to obd1. I dont know if it's possible to convert it to obd0 but I dunno, just a thought. Get some pics of the engine block code and the ecu
Old Jun 26, 2008 | 08:19 PM
jpnolan's Avatar
no its a d16y7 no vtec on a pm6 ecu which is obd1 on who know what wiring harness theres no conversoin on the end so it must be an obd1 harness. its weird ****
Old Jun 27, 2008 | 06:14 AM
ORIGINAL: jpnolan
isn't the pm6 obd0?
Old Jun 27, 2008 | 11:21 AM
jpnolan's Avatar
PG6: 88-89 Integra (all makes)
PM5: 88-91 Civic/CRX DX
PM6: 88-91 Civic/CRX SOHC Si
PM7: 89-91 DOHC ZC (JDM 'EF' ECU)
PM8: 88-91 CRX HF
PR2: 89-91 ZC (Euro)
PR3: 89-91 JDM B16A EF8/9
PR3-J00 or J51: 92 JDM Integra B16A EF8/9
PW0: 89-91 JDM B16A EF8/9 DA6-XSi
PR4: 90-91 Integra LS/GS
PS9: 88-91 4 door Civic EX Auto
P05: 92-95 OBD-1 Civic CX
P06: 92-95 OBD-1 Civic DX
P07: 92-95 OBD-1 Civic VX
P08: 92-95 OBD-1 Civic D15 JDM
P0A: 94-95 OBD-1 Accord EX
P13: 93-95 OBD-1 Prelude Vtec
P14: 93-95 OBD-1 Prelude Si (non Vtec)
P27: 92-95 OBD-1 EG JDM Civic 1600 sohc
P28: 92-95 OBD-1 Civic Si/Ex
P30: 92-95 OBD-1 DelSol DOHC Vtec Si/EG SiR
P54-G31: 1997 Honda Accord 1.8 LS
P61: 92-93 OBD-1 Integra GSR
P72: 94-95 OBD-1 Integra GSR
P72: 96-00 OBD-2 Integra GSR
P73: 96-00 OBD-2 Integra Type-R (JDM & USDM)
P74/75: 92-95 OBD-1 Integra LS/GS
P75: 96-00 OBD-2 Integra LS/GS
P2N: 96+ OBD-2 Civic HX Coupe
P2P: 96+ OBD-2 Civic EX Coupe
P2E: 96+ OBD-2 Civic DX Coupe
P2M: 96+ OBD-2 NZ Civic SOHC VTEC
P2T: 99+ OBD-? Civic Si Coupe
P5P: 97-00 OBD-2 Prelude Type-S (JDM ECU)
PBA: 97+ US Acura 1.6EL
PCT: 98+ JDM ITR / CTR
PCX: 99+ OBD-? S2000
wait idk maybe it is obd0 what does this mean for me?
Old Jun 28, 2008 | 12:43 PM
jpnolan's Avatar
I'd like to start this post off with :'(. Apparently to get my civic to pass smog my mechanic says if he does it its going to be around $2k. The cost is so much because the wiring on this car was done so horribly when the dpfi was changed to mpfi. exhaust is leaking catback is destroyed, there are so many problems with this engine/wiring/ everything. Although I love this car the body is in goodish condition so i want to keep it. Ive been thinking about swapping a D16ZC into it but my boss at work (idk how much he actually knows about hondas) says that it wont pass smog with this motor? Hail i bet you would know if this is right and some advise. I want to buy it online so that i can get a Waranty. So the turbo plan might be out of the question. The mechanic will be done next week when i find out how much it will cost ill make my decision.
