Little Help with this Turbo PLEASE
Old Jun 17, 2007 | 04:36 PM
Deathsim89's Avatar
Default Little Help with this Turbo PLEASE
Hi Guys Iam new here and i dont know a hole lot about the fuel management system/ the ecu i just purchased a turbo kit .50 A/R / .63 HOT SIDE
STAGE III WHEEL this is the site if u wanna check it out http://www.ssautochrome.com/prod.itml/icOid/1836 i was just wondering if i would need to replace the stock fuel injectors with 310cc injectors or if the stock ones would be enough i have a D16Y8 Vetc. Also any other thoughts about this turbo i would like to hear Thanks ALOT guys
Old Jun 17, 2007 | 05:01 PM
Mr Mobsta Man's Avatar
Default RE: Little Help with this Turbo PLEASE
...Thats not a good kit. The welds are crappy and it's all knock-off parts. You shouldn't use it but if you still insist then get an oil resistor for the oil line to the turbocharge because some ppl that use their turbos say that it will make the seals last longer.
Old Jun 17, 2007 | 05:03 PM
Deathsim89's Avatar
Thanks for the reply I wont use it if enough ppl think its bad i mean i mostly deal on engine swaps etc but i want it to work
Old Jun 17, 2007 | 05:09 PM
In my opinion and most of the other's on this forum I can say that you should sell that kit if you have already bought it and peice together a kit yourself and it should cost about the same and the kit you put together will be quality stuff and will last. Along with the kit you will need fuel management. DSM 450cc injectors with a resistor box and clipsare a common setup for cheap or you could get RC Engineering's 440cc injectors that are plug and play but they are more expensive. The best form of fuel management would be a standalone like what aem makes but that isn't nessesary, you could get a conversion harness if your car is not OBD1 then get your ecu chipped and tuned with a tuning program by a tuner. Also stay away from fmu's and piggyback fuel systems. There is a start for you, there is much you can learn and probably should learnabout before boosting a car.
Edit: I almost forgot, do a compression test and make sure you don't have any cel's to make sure your engine is in the right condition for a turbo. Read some of the sticky's in the nitrous forums, there is a wealth of info there.
Old Jun 17, 2007 | 05:21 PM
Deathsim89's Avatar
wow lol u shure do know alot thanks man your replys are very helpful thanks alot i will take your advice i had just purchased this kit today so i can still cancel it thanks again
Old Jun 17, 2007 | 05:36 PM
Deathsim89's Avatar
ahhh crap i should have found this forum b4 i bought it >.< i just read the sticky about ssautochrome lmao
Old Jun 17, 2007 | 05:41 PM
riceburner700's Avatar
yeah most newbs just dive right in before testing the waters lol. j.k
Old Jun 17, 2007 | 05:45 PM
Deathsim89's Avatar
>.< lol
Old Jun 18, 2007 | 02:26 PM
MY99SI's Avatar
i'll say this.. once in a while you get some good things from that company.. ive seen2 out of 6 manifold that ive been around last
the others broke and had to be replaced.
ive been around a friend of mine for a while. he's on a t3 setup on his GSR teg. it goes 13.28/104mph. i have it on video for those who dont believe me.
on a vafc hack, 440 RC engineering inj. and a stock clutch (dont know how that happend) and 129K on the clock
schirminator
Forced Induction (Turbos, Superchargers, Nitrous)
Jun 7, 2014 04:50 AM
eg9
Jun 1, 2006 07:42 PM
lacivic
May 20, 2006 11:05 PM
mikeyb16a2
May 7, 2006 03:27 PM
LowLife
Mar 22, 2006 08:58 PM
