Need help
Old Apr 24, 2010 | 07:42 AM
cruiser56's Avatar
Default Need help
we have a 1996 civic with a D16 head and a D15 block (mini mee) we have turboed it and now we blew rod. what are our options. Replace rod and have it happen again. Replace internals with turbo rods and pistons. or change block out with something else maybe b18. We dont have tons of funds. If we use the b18 what about tranny and everything else.
Old Apr 24, 2010 | 11:35 AM
just get another block, go for a d16, then upgrade the rods and bearings, also get a thicker head gasket to help lower the compression, it will help take the strain off the rods. how much boost are you running? the b18 block will not bolt up to a d15 or d16 head or a trans, the b series motors are way different.
Old Apr 24, 2010 | 01:33 PM
cruiser56's Avatar
Default boost
We are only going to boost about 8-12lbs. I found someone with a d16 block he is asking 275 says. It has about 120k on it. Is this a fair price for something like this
Old Apr 24, 2010 | 01:45 PM
for just a block? stock...no thats way to expensive, you can find complete motors for that price. keep looking. where are you located, we may be able to help ya out
Old Apr 24, 2010 | 02:16 PM
cruiser56's Avatar
Default Location
we are located in Fond du Lac, WI halfway between Green Bay and Milwuakee
Old Apr 25, 2010 | 12:52 AM
Did you get tuned after installing the turbo?
How much power is it making?
The difference between 8 and 12 PSI is a lot. What turbo is it?
What specific head and block is it? D16__, D15__
TunerShark
Sep 23, 2006 05:27 PM
rx9790
Nov 1, 2005 05:53 PM
Jas10hon
Jul 4, 2005 10:35 PM
CivicCrazy
Nov 29, 2004 11:50 AM
