nitrous beginner
Old Feb 21, 2006 | 12:57 PM
civicjuju's Avatar
Default nitrous beginner
is anyone running juice on a d16y8?
i'm thinking about doing a 50 shot but still need some advice anyone?
Old Feb 21, 2006 | 01:01 PM
ef4life's Avatar
Default RE: nitrous beginner
a good rule of thumb every 50 hp you should retard timing one degree, and you might need to run colder spark plugs if you spray often. just keep your eye on the air fuel ratio with a guage, and don't hold it on longer than a 1/4 mile run at a time
Old Feb 21, 2006 | 01:04 PM
civicjuju's Avatar
so retard timing on degree and run colder spark plug
now do i need any tunning? do i need to change the ECU?
Old Feb 21, 2006 | 01:09 PM
dj_ipirate's Avatar
what if your a 7th gen. how do you retard the timing... (no distributor)
Old Feb 21, 2006 | 01:14 PM
ef4life's Avatar
i never said to turn a distibuter, but retarding the timing is to avoid detonation, i am not sure how he has to do it but i is a good safety precaution, but with only 50hp, you could get away without the timing change
there will be no need to change your ecu, and there shouldn't really be a need to due any tuning if the car runs good and the fuel pump is good enough to supply the extra fuel.
Old Feb 21, 2006 | 01:16 PM
ef4life's Avatar
here is an msd ignition that automatically can retard timing for nitrous. http://www.msdignition.com/sci_1.htm
Old Feb 21, 2006 | 01:21 PM
civicjuju's Avatar
sweet man thanks
what kit would you recommand?
whata shuld i expect horsepower wise? right now i have intake headers exhaust+ nitrous?
thanks
Old Feb 21, 2006 | 09:11 PM
riceburner700's Avatar
if you live at sealevel probably around 160-180hp and if you live up in the mountains like us coloradoers probably around 140-160
Old Feb 21, 2006 | 10:42 PM
Pete's Avatar
I want FINALIMPACT to post so we can read his SIG in this thread.
Old Feb 21, 2006 | 11:07 PM
civicjuju's Avatar
ORIGINAL: riceburner700
lololol yea...i live in colorado too....lol
