Non intercooled Turbo Kit
Old Jul 19, 2006 | 09:13 AM
Default RE: Non intercooled Turbo Kit
ORIGINAL: AgentofDarkness
ORIGINAL: Forty04
Pm me if you're interested in the sites I've been reading through.
Or you could put the sites in a list and make a sticky.
I would, but I don't think the "uppers" would be very happy about me posting links to other forums
Old Jul 19, 2006 | 09:27 AM
03civda's Avatar
I would stay away from using a turbo without an intercooler. Turbos generate an outrageous amount of heat, and with nothing to cool it, it will put a lot of wear and tear on your engine. Regardless of running low boost, the heat is going to still be there, and it is a risk. Good luck, and I hope eveything works out for you!
Old Jul 19, 2006 | 01:35 PM
gsumano's Avatar
ORIGINAL: Kolhoznik
nothing wrong with no intercooler....jsut gotta run less psi through it...
like the greddy kit that does not included an intercooler and its fine to run it at a low psi.
Old Jul 19, 2006 | 06:22 PM
ScoobyAddict14's Avatar
formerly aryiman98civic
or just buy each part piece by piece when you have the money
thats what im starting to do, i spend 2-3 hours a night looking on the web for good deals and also just reading up on a lot of info on the web...i posted a site that explains everything for the turbo in this section
good luck
Old Jul 25, 2006 | 12:00 AM
10isAce's Avatar
I'm running a non intercooler turbo system at 7psi on my 95 civic d15/t3 (164 whp on dyno). I've had it for over a year like this. The intake does feel too warm to keep my hand on for more than a second, but I have had no problems with detonation. A/F ratio is good and have had no detonation.
However, the oil seal on the turbo is leaking a ton of oil now. I wonder if the hot compressed air is making the engine run even hotter and somehow blew the seal. Or the old saab turbo died of natural causes.
I am going to put an intercooler on with my next set up, t3/t4 with bigger injectors and safc.
I didn't let not having the $ stop me from boosting, just do it and run 6-7psi.
Old Jul 28, 2006 | 01:33 AM
BlackDragon's Avatar
ORIGINAL: neon3kgt
you can get one later... and just run like 6psi.
you sir are an idiot. Running an non-intercooled setup isnt safe. Would you take that chance on a b16? maybe a d15b7 cause who ****ing cares...not B series. Lets also try and remember that you cant run 6psi on a gt35r and 6psi on a t25 and make the same power.
new2honda
Aug 21, 2014 05:49 PM
giwatcher
Feb 14, 2009 09:14 AM
sjmcgarrah
Apr 16, 2008 04:23 AM
Marty
25
Feb 3, 2006 11:22 AM
