Oil Sandwich Adaptor
Old Aug 1, 2008 | 08:40 AM
bcrichguitars's Avatar
Default Oil Sandwich Adaptor
I have a turbo'd d15b vtec, soon to be over 300hp. I am not running an oil sandwich adaptor or an oil cooler, I know that this is highly reccomended. How many of you guys are running a setup with the sandwich adaptor? If anyone can reccomend some good brands for the cooler/oil sandwich adaptor, that would be great. Also I have read that if you use hose clamps and hoses they usually always come loose at high rpm and cause engine failure, what can I use insted?
Thanks
Old Aug 1, 2008 | 03:45 PM
gsumano's Avatar
You don't need an oil sandwich adapter for high hp goals. Just a week ago, i took my oil sandwich adapter off because it was a PITA when changing the oil filter. Damn thing would get unscrew from the block first instead from the filter
(where the hell are all the little smiley's???????)
Old Aug 1, 2008 | 10:14 PM
Any other opinions?
Old Aug 2, 2008 | 12:05 AM
Thanks
Braided stainless steel turbo oil lines?
Old Aug 2, 2008 | 10:26 AM
ScoobyAddict14's Avatar
formerly aryiman98civic
DO NOT get a sandwich. They are more pain then they are helpful.
Old Aug 15, 2008 | 09:28 AM
arust45's Avatar
I don't have an oil cooler because of the simple fact that I am using all my money to replace parts as they break, but I still believe there is no excuse not to run an oil cooler with a turbocharged setup. I've never had a loose line that couldn't be remedied by zipties, hose clamps, and/or barbed fittings. Unless I am reading the question incorrectly, sounds like people don't like messing with sandwhich adapters because they require a little extra work every 8-12k miles that the oil filter is replaced.
________
YourNatalie5
Old Aug 17, 2008 | 03:23 PM
GReddy_Civic's Avatar
Snail'n Admin
I bought a greddy sandwhich adapter and havent had a problem with it all
Old Aug 17, 2008 | 04:39 PM
FlipHKD720's Avatar
i bought a freaking $30 sandwich adapter and expected it to leak and ****, but it's been perfect so far. Really easy, i highly recommend it, but maybe i just got lucky.
Old Aug 19, 2008 | 11:08 AM
Greddy and Flip, what type of oil cooler are you running with it?
Old Aug 20, 2008 | 05:00 PM
FlipHKD720's Avatar
nothing aftermarket for me
