question regarding turbo setup
Old Aug 15, 2007 | 11:32 PM
93sir's Avatar
Default question regarding turbo setup
I just finished my turbo kit in my EG...I have a few questions that i need answered before i turn my key. First of my setup is T3/T4 turbonetics, 450DSM FI, Hondata s100, Walbro 255lbh pump, Tial wastegate..I have a question regarding a fuel pressure and timing... What should my fuel pressure be if im running 8psi of boost....also what should my timing be advanced to right now its -2,1..and my fuel pressure is about 42psi...also any other checks before i turn my car on....THANK YOU
Old Aug 15, 2007 | 11:33 PM
93sir's Avatar
Default RE: question regarding turbo setup
OH by the way my motor is B16A2...
Old Aug 15, 2007 | 11:43 PM
93sir's Avatar
what i mean by adjusting the timing is cam gears....I have aem trutime pulley set what should the degrees on that be on turbo b16...
Old Aug 16, 2007 | 08:32 AM
cpl rampage's Avatar
start at zero, and then adjust when u get to the tuner, u will also want to crank it over with the fule pump and dizzy diabled so u can prime the oil system.
Old Aug 16, 2007 | 07:56 PM
polo708's Avatar
normal fuel pressure is around 40-50... varies slightly for each setup.
Old Aug 16, 2007 | 09:40 PM
SovXietday's Avatar
Stock fuel pressure is fine, no advancing/retarding the cam timing. Not yet anyway, probably never will need to until you put some real radical cams in there.
johnwohl
Jan 9, 2008 07:34 PM
Obligatory
Dec 3, 2007 11:11 AM
Shbek
Oct 21, 2007 07:59 PM
CiViC_NaTioN
Feb 26, 2007 12:59 AM
Tonymore
Apr 29, 2006 04:00 PM
