Quick!
Old Jan 13, 2006 | 04:51 PM
XCM828's Avatar
Default Quick!
OK, turbo's all installed, but I'm not getting any oil to the turbo. I've cranked it over to the point where the battery is starting to get low. What did I do wrong?
Old Jan 13, 2006 | 05:45 PM
finalimpact's Avatar
Default RE: Quick!
where did you tap into for oil supply? also try removing the feed line from the turbo and turn the engine over(of course you will need to catch the oil) and see if any oil comes out from the line. if not, the remove the line from where you tapped into and see if it has any oil pressure there. if not, remove whatever you used to tap into for oil and see if oil comes out(which it should)
Old Jan 13, 2006 | 05:55 PM
Remmy's Avatar
Default RE: Quick!
Oooo boy, i cant wait till you get that on!
Old Jan 13, 2006 | 08:15 PM
XCM828's Avatar
Default RE: Quick!
Yeah, finalimpact that's what I had been doing, but no oil was coming out. Figures that right after I post this and PM a bunch of people, my dad and I decide to go out and try it one more time, and voila! oil came a shootin' out. So I got the car started, but it seems that I somehow forgot to put the o-ring on the end of the downpipe, so exhaust was shootin out everywhere. It did sound pretty freakin sweet though. I'm going to finish it up and take it for a test drive right now.
Old Jan 13, 2006 | 09:48 PM
Pete's Avatar
Default RE: Quick!
oh youre goin to love it.
Old Jan 13, 2006 | 11:56 PM
riceburner700's Avatar
Default RE: Quick!
Just dont go ripping down the road, shift at 3k encraments and listen to the engine, if it sounds alright and no knocking sounds, then you can go ahead and boost it all you want
THE_CRIPPLER
Dec 6, 2005 08:26 AM
02CivicEX
May 4, 2005 07:03 PM
supawiseguy
Mar 30, 2005 01:21 PM
Remmy
Jan 24, 2005 03:08 PM
dalifts
Sep 22, 2004 10:26 PM
