quick question about this turbo
im new to turbo's so i just wanna make sure im getting the right stuff...
will this turbo posted in this ad work on my d16y7 motor??
http://sacramento.craigslist.org/pts/1638260717.html
oh and if its a b series turbo and i wanna put it on a d series engine all i need is a different manifold right??
Any turbo will work if you have a manifold and downpipe that fits and you have room in front of the engine.
What you need to worry about is if it will work the way you want it to.
You have to pick your turbo based on power goals, streetability (which is usually based upon where the turbo spools at and how much power you make), the particular turbo's reliability and performance, and fitment in the engine bay... there are other factors.
Here is a FAQ that will help explain some things for you.
Right now you are going to need to decide on a power goal (your engine is good for about 200 WHP on stock internals if it's in optimal condition).
Then when you do that, take a look at this page. You'll need to get a proper identification of this turbo, the model number. It'll be GT______. Then you'll be able to find out how much power that turbo is capable of.
I am pretty sure that 200 WHP should be easy to reach with that turbo.
thank you that really helped out alot.. im just looking to make some where around 160hp or more if possible not to much where ill blow the engine.. my stock manifold cracked so i decided i want to turbo it...
If all you want is 160 WHP or so I wouldn't even bother getting a turbo quite that large.
Actually, I wouldn't even bother getting a turbo at all. You'd be better off with a used Jackson Racing Supercharger. You should make 160 WHP I am pretty sure, and they are cheaper and more simple than a quality turbo kit. I'm not even sure if you'd need to upgrade fuel injectors to make 160 WHP (don't take my word for it though). You would need a tune though.
It just wouldn't fix your exhaust manifold problem... but for that you could just get an aftermarket header such as the one made by Megan Racing, which is sold for ~$150.
oh no im just saying i wanted atleast 160 i would love more ofcourse.. and i just love the sound of a turbo and bov.... well i just looked on craigslist and found a few good deals.. so tomorrow ima start calling all of them..
look out for shaft play, worn oil seals (you'll have to ask them about this to know if it leaks/burns oil), and chipped turbine fins.
To make sure it's legit look for markings and the tag on it. Most turbos have a tag riveted to them.
okay thank you... i decided to try to piece together a decent turbo. so after i get this turbo ima ask more about intercoolers,injecters,boost controller...etc everything... i really appreciate all the help you given me so far. thank you...
p.s i been painting and polishing my engine this past week it's looking good ill post pics when im ready to show you guys..
zsatbecker
13
Oct 17, 2008 06:11 PM
THE_CRIPPLER
Dec 6, 2005 08:26 AM
