Reliable for 350whp?
Old Mar 4, 2008 | 07:12 PM
arust45's Avatar
Default Reliable for 350whp?
Just swapped out my 75 mm vitaras for .02" over. I was told that these pistons in conjunction with my h-beams will hold 350whp. Also have ARP's, oem gasket, block guarded, and y8 oil pump from the dealership. Been reading about the shortcomings of the y8 pump, does it need to be ported or shimmedfor a reliable 350whp turbocharged d16y8? Also what power differences are noticeable with the slightly larger bore size?
________
LAX PATIENT REMEDIES CLOSE
Old Mar 4, 2008 | 07:20 PM
riceburner700's Avatar
Default RE: Reliable for 350whp?
always shim a dseries pump. they suck at oiling, yes the vitaras/eagles will be plenty good for 350
Old Mar 5, 2008 | 09:08 AM
FlipHKD720's Avatar
Sovxietday has an OEM oil pump that has been ported and he's running more than 350hp i beleive. So that could be an option for your oil pump.
He also has Vitaras, Eagle rods and ARP headstuds, i say you'll be good with your setup.
Old Mar 5, 2008 | 06:59 PM
arust45's Avatar
I trust his judgement, but I wonder how long he has been running that setup. I don't trust those cast vitaras when the life of my engine is at stake. I'm only planning around 260whp for my high boost setting and keeping the low between 225 and 235.Not lookin to make perty numbers at the track, just want a fun project without having to get new axles and transmission work done...not yet at least. At least I have the 1000 mile break in period to think it over. Any opinions on megasquirt?
________
Leather Cams
tinman1412
Oct 29, 2006 04:37 AM
RedlineZero
Jul 27, 2006 04:42 AM
opivyspike
May 18, 2006 12:05 AM
tallford78
Apr 16, 2006 12:22 PM
garosenb
Mar 11, 2006 01:16 PM
