RUNNING NITROUS
I HAVE 94 B18B LS ON MY CIVIC AND I NOS SYSTEM FROM ONE OF MY BOYS. HE SAID HE WAS RUNNING 100 SHOT OF NITROUS I WAS JUST WANT TO KNOW IF A 100 SHOT OF NITROUS IS TO MUCH FOR THAT MOTOR ALL I HAVE IS BOLT ON THINGS I HAVE NOT TOUCH THE INTERNAL PARTS OF THE MOTOR?
make sure your fuel pump is up to the job, also a adj fuel press regulator is a must IMO. take the car to a shop with a dyno and have them tune the car with the 100 shot. as long as you understand how to use nitrous as far as pro's and con's you should be fine. ei, nitrous bottle pressure should be in the range of 900-950 psi upon activation. this is when you will get a tru injection on liquid nitrous. anything higher and you will get gas instead of liquid which in turn will cause you to run lean and possible destroy your engine. ive ran 75 shot direct port on a d15 when others claimed it would be destryoed at 50 shot. its all about tuning and using it properly.
uhm 100 shot is a lot for a stock motor but it cvan handle it as long as its done right. Make sure it gets tuned...tuning is very importnat also u may want to get adj cam gears to adjust the cam timing for the nitrous. Just get it tuned and installed properly and it'll be ok
