Are there such thing as legit inexpensive turbos?
ok i ment turbo manifold but the one he has is a b series so i gotta get a d series one.. uh i hope it fits... from what he said he ran it on his honda.... ill find everything out when i drive down there and take a look at it... but jsut to make sure if the turbo was origanally for a b series engine will it fit on a d series engine with a different manifold??
Around $100 for no-name ones on eBay. As long as they're cast iron, no-name ones are typically fine.
But you'll want to try as hard as possible to get one exactly the same but for D-series, especially if it comes with the downpipe. This will make your install easier and help to reuse the downpipe it comes with (if it comes with one).
Check on eBay for Honda CRX HF exhaust manifolds. You can usually find them pretty cheap... you can weld a turbo flange onto the collector and you have a cheap log-style manifold; not the prettiest thing on earth, but it's cheap and works. I'd imagine a muffler shop wouldn't charge much to fab up a down-pipe if you'd want to go that route.
Well I found a kit but its for 2001-2005 Civic (Europe) or EP3 (I believe).
I was wondering if I could get it but just do some minor modification like pipes but as long as the manifold turbo and everything fits in the engine. Does anyone know if that would work...as long as I had some modification.
