Turbo Charger Build-up
Old Feb 23, 2008 | 09:59 PM
SleeperChild's Avatar
Default Turbo Charger Build-up
Im about to install a turbo on my 95 civic 1.5 SOHC. i was wondering if there is any recomended upgrades or modifications i should do to the engine to keep it out of the garage for repairs.
Old Feb 23, 2008 | 11:35 PM
didder's Avatar
Default RE: Turbo Charger Build-up
we need a lot more info in order to help you further.
a.) what type of turbo
b.) how much boost is that turbo planning on running
c.) have you done a compression test? and are the numbers within 10%
d.) etc...
and you should be fine stock, as long as you keep it under 200whp, and make sure you get a good tune, the tune is what makes the car reliable or not.
Old Feb 24, 2008 | 10:37 AM
Mr Mobsta Man's Avatar
How dependable your setup will be is directly dependent on the amount of time and money you are willing to spend and how much knowledge you have about what you are doing.
leco516
May 2, 2006 09:54 PM
javierdagreat
22
May 19, 2005 11:29 AM
javierdagreat
May 18, 2005 07:02 PM
INJENalltheway
Feb 8, 2005 06:18 PM
Super Mario
13
Oct 31, 2004 12:28 AM
