Turbo charging d15b7
Old Dec 1, 2004 | 07:28 PM
sacicons's Avatar
Default RE: Turbo charging d15b7
oh hell yeah. sohc turbos are sweet.
Old Dec 1, 2004 | 08:03 PM
ohbiskits's Avatar
cool...thanks...hey just a little tid bit...my friends sponcer is asking him to hit 560 hp on a SOHC...on his old one he had 420 on the bottle...i cant wait to see that one finished..alright thanks for your help man
Old Dec 3, 2004 | 12:54 AM
Super Mario's Avatar
where did you find your kit?!?!?! I have the same car, except sedan, and was looking for a turbo kit. couldn't find one. could you help me?!?!
Thanks
Old Dec 3, 2004 | 08:30 AM
niteryder's Avatar
just go to your local import shop (if its a good one)
Old Dec 3, 2004 | 11:58 AM
there aren't realy any good ones around here.
Old Dec 3, 2004 | 04:17 PM
ohbiskits's Avatar
u have the same car as me or as classyash?...you can check this to see if they have any for your motor
Old Dec 4, 2004 | 09:41 PM
classyash. 95 civic dx sedan d15b7 16 vlave. I checked out that site they don't have any for my engine. thank though!
Old Dec 5, 2004 | 04:17 PM
XCM828's Avatar
ORIGINAL: classyash
Thanx for the info its done 140k but its bin well looked after, regular oil changes etc just want some decent power outta it as it to slow nd cant afford to insure a b16a.
If you are only going to be running 6 - 7 psi on an engine with 140k miles on it, 102hp, and without any type of engine management or boost contoller, then i would say scrap that idea. You will get some gains (i'm guessing anywhere from 30 - 60 hp), but it definetly wouldnt be worth all of the work. Instead I would go for some kind of engine swap, because you will have the same, if not more, horsepower than if you boosted, and you would still have the option of boosting to gain even more horsepower.
Old Dec 5, 2004 | 06:30 PM
Kappa22's Avatar
I have found that stock 4G civic engines actually make damn good sleeper engines. I have a friend who has a 90 standard HB (D15B1, 70hp/82 lb-ft. stock), and he runs 10 lbs. and a 40 shot on stock internals. The only thing he had to do was convert to MPFI (pretty simple). He runs 13's regularly, and it's a daily driver. The 4G D-series engines have really solid bottom ends for their size, since they have cast basket braces under the crank, so they are able to hold together pretty well.
Old Dec 5, 2004 | 06:40 PM
XCM828's Avatar
The D15B8's rods are practically toothpicks. I don't know bout the D15B7 but I'm guessing that they are pretty much the same.
