Turbo D-series
Old May 16, 2006 | 05:54 AM
F23AccordLX's Avatar
Default Turbo D-series
I am a really big fan of the D-series motor. I have a D16Z6 in my 97' Civic EX with 71,000 miles and i want to know if it would be ok to buy a small turbo kit and only run 4-5lbs of boost and would it be reliable?
Old May 16, 2006 | 08:35 AM
Remmy's Avatar
Default RE: Turbo D-series
Yes actually. I think Petes car has 120k+ on his screaming 5th gen and that crazy sob is running 9lbs.
Old May 16, 2006 | 10:22 AM
Marty's Avatar
Yea you should be fine, try and not look at it as how much boost you can run safely but more so how much tq. With a tune that is good your engine will hold a good 220 to 240whp bone stock.
Old May 16, 2006 | 11:30 AM
riceburner700's Avatar
you could run 7 pounds all day long. but pete also has arp's in his head so that helps out a bunch...
Old May 18, 2006 | 12:11 AM
thedougler's Avatar
What are ARP's?
Old May 18, 2006 | 10:56 AM
mr2azzkicker's Avatar
ORIGINAL: thedougler
What are ARP's?
ARP is a compny that makes high strength aircraft quality bolts. They make them for heads, rods and flywheel applications. It is cheap insurance in my opinion. If you are building an engine use ARP bolts where ever you can, I always use them in engines.
Old May 18, 2006 | 10:58 PM
basicly they are the strongest bolts you can buy for an engine, highly recommended
Old May 19, 2006 | 12:52 AM
thedougler's Avatar
allright i will keep that in mind
Old May 24, 2006 | 10:58 PM
t34me's Avatar
Cant go wrong man. D-series have the advantage of low end torque, so combined with some mid to high end power, you got yourself a quick little ride. I have a JDM D15B in mine with a T3 running 8lbs, and its a serious blast to drive.
FastFwd
Dec 13, 2005 10:20 PM
S240161
Nov 3, 2005 08:35 PM
00exinfl
EK Swaps
Mar 28, 2005 10:29 PM
phatek4
Dec 30, 2004 02:09 AM
