turbo oil lines
Old Feb 3, 2007 | 10:14 PM
mugen23's Avatar
Default turbo oil lines
wheres the best place to run/hookup the turbo oil lines too, where/what part of the motor?
Old Feb 3, 2007 | 11:21 PM
ScoobyAddict14's Avatar
formerly aryiman98civic
Default RE: turbo oil lines
get an oil sandwich and it will make your job a lot easier.
get an oil line kit and it comes with a T for the block. you take the map sensor off and replace it with the t fitting. if you have a sandwich you dont have to take off the sensor, you just remove your filter, put the sandwich on and the filter on the sadwich. its got inlets to put the oil feed line in and your done. the oil return will go to your oil pan
Old Feb 4, 2007 | 12:00 AM
riceburner700's Avatar
those things were the biggest pain in the *** to screw in the block straight because of the tightness in that area
cvcrcr99
Dec 31, 2012 07:44 AM
b8teen
Apr 11, 2010 05:14 PM
oilltd
Jun 10, 2008 04:06 PM
k_dogg70
13
Jun 12, 2007 03:46 PM
