turbos
Old Nov 23, 2007 | 05:55 AM
lew1's Avatar
Default turbos
hi there this question might have already been asked but im wanting2 know if it is possible 2 use a diesel turbo on a petrol car even if it has already been used with dieselthanks
Old Nov 23, 2007 | 06:13 AM
FlipHKD720's Avatar
Default RE: turbos
like, a huge turbo off of a diesel truck? Yes, technically it is possible, but youre little 4 cylinder is so small it will barely be able to spool that thing up and make any power. You're going to want to go with a smaller turbo, (T25, T28, T3/T4, 14B, etc.) if anything.
Old Nov 23, 2007 | 10:01 AM
lew1's Avatar
Default RE: turbos
no i would b useing just a normal diesel car turbo. so there is no difference at all between diesel and petrol turbos
Old Nov 23, 2007 | 08:17 PM
Littlehag's Avatar
Default RE: turbos
they both do the same thing... put more air into the engine
as long as it's in good shape and you know what you're doing, everything should be ok
Old Nov 23, 2007 | 11:26 PM
lew1's Avatar
Default RE: turbos
thanks alot guys that is a big help i couldnt think of a reason y they would b different but just wanted 2 make sure cheers
Old Nov 27, 2007 | 07:35 PM
lynch10586's Avatar
Default RE: turbos
hey i have a d16y8 sohc is a t25 turbo a good size and what type of boost should i be running with stock interals?
Old Nov 27, 2007 | 07:46 PM
gsumano's Avatar
Default RE: turbos
ORIGINAL: lynch10586
That's a good size turbo to make 200whp on a d16. The boost level doesn't matter, what matter is how much horsepower you make. A stock d16 can safely make 200-220whp on stock internals.
Old Nov 27, 2007 | 08:24 PM
FlipHKD720's Avatar
Default RE: turbos
levaing that turbo internally gated at it's 8 PSI will do just fine and put you around 200hp. For a simple, mellow boost setup, the T25 is your best bet for sure, just get a good tune and some headstuds.
AgentofDarkness
Jun 9, 2005 10:42 PM
meangreen
26
Mar 11, 2005 10:26 PM
Swift
Feb 17, 2005 03:34 PM
HONDA PUSHA
Jan 11, 2005 06:33 PM
paul
Oct 11, 2004 02:09 PM
