Vacuum Lines
Well, the golden eagle manifold has all of the ports still closed, you have to drill out the ones you're going to use. Right now I'm using 3, wastegate, BOV, Boost Gauge.
I can't speak for all of them, but the ones you aren't using you would need to seal.
Well you dont have to seal them if you never tap into them. The vac ports have threads on em so you buy a hose adapter and screw it into the manifold. If you only need three, tap three.........the other ones are going to remain sealed until you open em up by drilling thru em.
I'm assumeing that drilling into it would also put shavings into the mani, you probably can't just shake them out so how would you make sure you get them all out, I dought you would want to hook it up while it still had shavings in it.
Edit: nvm I'm an idiot, you could probably just use an air compresser.
ORIGINAL: Mr Mobsta Man
Pete, I only have worked with the golden eagle manifold, in which you drill out the ones you need as you need them. I'm not sure if all of them are that easy, but i'd hope so.
jusplayn85
May 18, 2006 03:59 PM
civic9988
Oct 24, 2004 07:22 PM
