whats the best injector size?
Old Feb 5, 2007 | 11:36 AM
tombakers's Avatar
Default whats the best injector size?
im running a b16a2 and am lookin to run around 9-10 psi what injectors are the most suitable. i already have a 255 fuel pump. also is it worth getting a fuel pressure regulator? cheers
Old Feb 5, 2007 | 01:09 PM
Default RE: whats the best injector size?
Personally I would not get an FPR..
You could probably get away with running 450's but if you want room for expansion, go with some 550's
Old Feb 5, 2007 | 02:08 PM
Remmy's Avatar
Im running the same motor with internals doing 10-11 psi and i use RC 440's. They are fine with me.
Old Feb 5, 2007 | 02:10 PM
ScoobyAddict14's Avatar
formerly aryiman98civic
when you add your fuel pump and if you had 450s it would really be like running 470s so you should be fine with running the dsm 450s. i will be running the dsms when my car is up and running.
Old Feb 5, 2007 | 05:29 PM
dfdon's Avatar
+1
Old Feb 6, 2007 | 07:57 AM
ORIGINAL: Remmy
What duty cycle are you running on those, any idea?
Old Feb 6, 2007 | 10:04 AM
SovXietday's Avatar
ORIGINAL: tombakers
9-10psi on what turbo?
Old Feb 6, 2007 | 10:15 AM
Remmy's Avatar
ORIGINAL: Forty04
ORIGINAL: Remmy
Your moms.
Old Feb 6, 2007 | 10:55 AM
ORIGINAL: Remmy
ORIGINAL: Forty04
ORIGINAL: Remmy
Your moms.
Thank you, that's very helpful
stylincompact
Jul 13, 2010 04:48 PM
T-flow cylinder heads
Oct 3, 2009 06:42 AM
bcrichguitars
May 26, 2008 09:27 AM
bcrichguitars
May 16, 2008 05:26 AM
Inferno21
Nov 21, 2006 05:27 PM
