Non-Honda Discussion Discussion of all other makes and models takes place here!
90 isuzu amigo
Old Jul 29, 2010 | 03:54 PM
90hatch12167's Avatar
Default 90 isuzu amigo
hoping some1 can help. since the amigo is close to a Honda passport so maybe some1 knows some things.
I have a 90 amigo and i don't have turn signals. I have everything but turn signals, so i have 4 ways. i just redid the harness all the way to the back from under the seat. and everything works fine and is well grounded. if i turn the switch for the turn signals on either way they make the clicking noise from the relay. but no lights. however sometimes when i do it the relay doesn't click like it should and makes a horrible buzzing noise. I replaced the relay. and that didn't seem to make a diff. i found the plug that goes from the switch for the signals and connects to the second part from there. if i have the turn signals on and they make the buzzing sound. f i touch a test light to the wire for the signal the test light will flash and then the relay starts clicking as it should. i located the ground under the hood and if i unhook it i get no turns or 4 way. so i cleaned that ground up then put it back and i still have 4 ways but no turns. any ideas? all fuses are good. sept i don't have the the fuse cover so i dunno what fuses do what relay. and i don't think the Haynes book i got tells. seems like turns would be same fuse as 4 way. I am drawing blanks here would really like some help. Thanx
Old Jul 29, 2010 | 04:27 PM
ive actually owned a honda passport which is a izuzu rodeo with a sunroof and stability control. i dont know why the hell they call it a honda when nothing on it it made by honda, its all izuzu and subaru and gm parts.
i would say you have a bad switch or the round blue relay that control the blinkers is bad.
Old Jul 29, 2010 | 04:43 PM
is the blue relay under the hood in that fuse box?
Old Jul 29, 2010 | 07:32 PM
it should be under the dash, its a round blue relay... its was makes the blinkers ..blink
Old Jul 30, 2010 | 02:31 AM
ok. mine isnt blue or round but thats what ive all ready replaced.
Old Jul 30, 2010 | 05:48 PM
then i believe its the actual switch
Old Jul 30, 2010 | 05:52 PM
yea. thanx for the help.
LANxCiv
Aug 1, 2010 03:13 PM
JayVee
Jul 26, 2010 04:20 PM
WallyLac
Jan 26, 2007 06:38 AM
Paulq
Dec 18, 2006 08:17 PM
dragin93
Jul 5, 2005 02:03 PM
