trustdestruction's Civic del Sol Si Project
Old Sep 14, 2009 | 09:33 PM
  #681
Lewy2k's Avatar
Vocalist
I played guitar for 2 years before I played with anyone else... but when I did, it's unreal. It makes playing a million times more fun and you feel like you learn much faster. If you havent jammed with friends before then you'll love it.
Old Sep 14, 2009 | 09:36 PM
  #682
Yea me and my other friend who plays guitar have been chilling and working on stuff but on saturday, the first time we jammed with our drummer, it was simply amazing. My creativity soared at that moment and now for some reason i'm good at making up stuff.
Old Sep 14, 2009 | 09:44 PM
  #683
Lewy2k's Avatar
Exactly. Its as if something heightens your creativity and instincs. Everything flows better by feeding off eachother either by opinion or just playing music.
Old Sep 14, 2009 | 09:46 PM
  #684
rc2904's Avatar
Yeah ever since my first ESP guitar ive been hooked so I just couldnt bring myself to get any other kind of bass. Next ill have to procure myself a good peavey bass head. My 5150 guitar head is a hell of a lot louder than anything else ive tried and it just cuts right through all the noise from the other instruments. I'll have to record a sample of my bands stuff for you sometime trust. You may like it.
Old Sep 14, 2009 | 09:59 PM
  #685
Speaking of recording, do you have any idea what I should use for recording the entire band at once, just to be able to hear it again?
I guess a bunch of mics and a USB mixer for my computer would work, right? What should I use for recording the guitars? Our amps don't have line outs on them except for a headphone jack but when you use that the sound only comes out the headphones. I have a microstack so my amp has an actual head on it and I guess I could just put a splitter on the head's outputs so it would go to the mixer and the amp? What would you recommend doing?
Old Sep 14, 2009 | 10:16 PM
  #686
rc2904's Avatar
DI box If you have two outputs on your amp you can run one to your speaker cabinet and the other to a di box (reduces the noise to line level). It sounds a lot cleaner for live sets to run to the mixing board through one of these than to mic your amp.
Behringer V-Amp I used this for just about everything. You can run guitar to this and use it for distortion, effects, noise gate etc. One output can go to your amp on its clean channel and the other you can either plug straight into the mic jack on your pc to record or run it to the mixing board for shows. Im definately getting the bass version of this if I decide im gonna stick with bass.
Both of these have some 'cabinet emulation' feature that gives the mic'd amp sound without all the stage noise and feedback of a mic'd amp. You can turn it on or off depending on preference or you can get a passive DI box for a lot cheaper if you want to skip the cab emulation altogether.
Old Sep 14, 2009 | 10:17 PM
  #687
danomatic93's Avatar
June 2010 ROTM
We used to do one recording together and then individually record while listening to the same recording. That method is okay for demos.
Old Sep 14, 2009 | 10:43 PM
  #688
Well my head has 2 outputs, but I have 2 speaker cabinets. (I need to use both speakers while practicing to be able to hear myself over the drums)
What if I ran a splitter on one of the head's outputs and then run that to a mixer input? Would that work?
But wait... doesn't a mixer allow you to put the mixer between the head and the cabinets so that there is a mixer output that goes straight to the cabinet? (and then it would communicate with the computer via USB).
I have a MacBook Pro with Garage Band on it so i'll be using that. I learned how to use it. I downloaded Logic Studio 9 but that's way too difficult for me to figure out right now. I want to be able to focus on playing right now, not learning how to record it.
But then the other problem is that my friend's amp is just a little amp and it doesn't have a head so all of the stuff is internal. It doesn't have an output besides headphones.
Basically what I want to do for now is just record our live sessions but with decent enough SQ to hear things clearly... that's where the mixer comes in, plus I can master the audio with Garage Band afterwards. I don't want to record tracks at separate times if I can help it. It makes the music feel artificial.
Old Sep 14, 2009 | 10:54 PM
  #689
I made a thread for this topic we are now having, it's in Off Topic:
https://www.hondacivicforum.com/foru...ad.php?t=78449
Old Sep 15, 2009 | 07:31 AM
  #690
Overurhead360's Avatar
I used to love jammin' back in the day, my drum set hasnt been touched in months... but anyways that should go in the other thread. How well does that h brace help? and your cat does look pretty dinged up. my twin loops like destroyed and im not that low, i think i need to get rid of my rear lip and pull it up alittle bit.
