00 HB rear brake disc conversion question
Old Oct 30, 2006 | 04:06 PM
opera936's Avatar
Default 00 HB rear brake disc conversion question
can anyone tell me where i can get such conversion kit and also does this have something to do with the brake fluid
Old Oct 31, 2006 | 09:51 PM
amg6975's Avatar
Default RE: 00 HB rear brake disc conversion question
Keep checking eBay for Civic rear discs, anything from 92-00 should bolt right up. Don't forget to get a proportining valve! 99-00 Si valve would probably work the best.
Other than the valve you'll need to make sure you have the trailing arm, wheel hubs, lugs, rotors, calipers, pads. Probably more stuff that other people will fill you in on.
Old Nov 1, 2006 | 09:10 AM
HARI.'s Avatar
you don't need to get the si prop valve. 96-00 civic prop valves are the same, but make sure to upgrade the brake master cylinder to a 7/8 or 15/16. you don't need to upgrade the brake booster, it is also the same. you can also use 90-01 integra rear disc brakes setup. make sure you get the e-brake cables w/ the setup that you are going to buy.
click on this and scroll all the way down for pics of the rear disc setup
Old Nov 1, 2006 | 08:08 PM
Nail I3unny's Avatar
anything from/for a 94-01 integra or 92-00 civic will bolt right up.
pkennedy
Nov 3, 2010 12:58 AM
xkeseriesi
Jan 22, 2008 05:29 AM
cohen_fetters
Nov 5, 2007 05:31 PM
TIcivic00
Oct 25, 2007 08:34 AM
