215/60R15 on a 97 Honda Civic HX
Old Feb 6, 2010 | 03:43 PM
jibblers's Avatar
Default 215/60R15 on a 97 Honda Civic HX
Has anyone ever installed this size tires on a honda civic? And/Or is it possible?
Thanks,
Jibblers
Old Feb 6, 2010 | 06:25 PM
I'm gonna have to say those are too big.
They have a diameter of 25.2" and are at least 8.46" wide
The correct 15" tire size is a 195/55/15 (or optional 205/50/15)
195/55/15 have a 23.4" diameter and are at least 7.67" wide
205/50/15 have a 23.1" diameter and are at least 8.06" wide (205 is pretty much the widest you should go)
Old Feb 7, 2010 | 01:52 PM
I've seen 245/35-16's on an EK. Care to explain how that won't fit?
(image courtesy of errdizzle of Honda-Tech)
OP, what offset wheels do you have? It's perfectly possible to run that tire size, but it require a little more work to fit properly than one of the sizes trust posted.
Old Feb 7, 2010 | 07:27 PM
But does it rub?
If yes, how much?
If it rubs while making a normal turn, then in my book they don't "fit". Sure, they technically fit on the car, but they don't fit when you're using it.
Old Feb 8, 2010 | 08:20 AM
According to the owner, it rubs at full lock. As someone who's had a car lower than that, I can assure you even the stock wheels rub at full lock when a civic is that low. So by that logic, the stock 14's don't fit on a car that low.
Tire/wheel fitment is all about setup; wheel measurements, tire measurements, rolled fenders, camber angle, etc. Also, keep in mind the OP probably won't have his car that low, so making the tire fit without rubbing will be a lot easier.
Old Feb 8, 2010 | 01:23 PM
I wasn't concerned about how low it is, since the OPs car is probably not that low. I should have been more specific... I am wondering if it rubs the inner wheelwell on turns.
Anyway, we both know that the OPs tires probably won't fit (or fit very well at all) because the sidewall is too high
Old Feb 8, 2010 | 01:48 PM
Even a 205mm wide tire rubs the inner wheel well when you're low enough... my old civic has the scars to prove it
Anyway, since the OP doesn't seem to come back, shall we continue the discussion?
Are you also taking wheel offset and wheel width into account? A 205mm tire stretched over an 8" wheel will obviously have different fitment characteristics than a 205mm tire on a 7" wheel. Also, keep in mind that a 205-series tire does not actually have tread 205mm wide. It's 205mm wide at the widest point, which is rarely the tread width.
(and I shouldn't have to tell you by now, but just in case... don't take offense to what I'm saying... I'm just bored and feel like having a discussion lol)
Old Feb 8, 2010 | 01:51 PM
Yea I don't think the OP is coming back
Stratocaster1968
May 31, 2009 08:04 AM
lakaiguy
Aug 9, 2007 07:52 AM
01CivicEX
Apr 2, 2006 01:25 PM
lakaiguy
Aug 1, 2005 01:06 PM
blackmagik_13
Jun 15, 2005 03:34 PM
