92 - 95 REAR poly bushings
Who makes a complete rear poly bushing set? I bought the Energy Suspensions "full" kit, had everything for the front but only the LCA for the rear. I loooked at Prothane, but they too seemed to only have the rear LCA. My car has 210k on it, the rear rubber bushings all need to be replaced.
i am about to undertake this same project as well.. with the exact same kit, the energy suspension master kit...the kits says it includes
- Front Control Arm Bushings
- Rear Control Arm Bushings
- Front Shock Mount Bushings
- Rear Shock Mount Bushings
- Front End Links Set
- Steering Rack Bushings
- Transmission Shifter Stabilizer Bushings (manual tranny)
- Ball Joint End Boots
- Tie Rod End Boots
there is also a cheap little set of trailing arm bushings to go with, other than those what will i be missing???
- Tie Rod End Boots
Energy Suspensions makes the trailing arm ones? I didn't see them listed when I looked - musta missed them. Prothane makes the rear trailing arm ones, 8-304, for$90 fromSumiit There are 3 (per side) that are missing fromthe Energy Suspension kit, that's the large trailing arm bushing, and then 2 "camber" arm busings.
MrLizard
Aug 21, 2008 01:53 PM
brunborg
Jan 14, 2008 08:38 AM
TurboEJ1
Feb 28, 2006 09:32 AM
