Bigger wheels...
Old Mar 1, 2006 | 10:29 AM
secondhandloser's Avatar
Default Bigger wheels...
I have a 1996 Civic EX coupe, and I want to beef up its appearance with some bigger wheels.
I would like to keep speedometer and odometer readings accurate, so I'd like to get thinner tires to keep the overall radius the same.
Thing is, I can't find what I need, maybe just because I don't know what I am looking for.
If anyone has any tips or links to what I need, that would be great.
My car has 14's stock, I'd like to put on 15;s or 16's.
Old Mar 1, 2006 | 12:32 PM
mill$civic's Avatar
Default RE: Bigger wheels...
well for 15" i would go with 205/50/15 that should sute you well.. im not sure about the speedometer changing, if it does it will be so little
Old Mar 1, 2006 | 01:27 PM
NTX's Avatar
NTX
this might help a little. https://www.hondacivicforum.com/m_159867/tm.htm
Old Mar 1, 2006 | 11:06 PM
riceburner700's Avatar
ORIGINAL: mill$civic
I know with the 15's i just put on today the max i could go was 195/50/15... If anything your speedometer will be more accurate because honda puts smaller tires on so your speedometer shows you are going 2-4mph faster than you really are, so you think you are going 45 in a 40 when really you are going 43mph
Old Mar 1, 2006 | 11:40 PM
silverbullet's Avatar
Check this link out, it is an awesome tire calculator. It'll do all your number crunching for you and tell you what your speedometer will read after your conversion.
Tire Calculator
EDIT: Personally I would go with 16's just because then you don't run the risk of rubbing.
Old Mar 3, 2006 | 09:29 AM
anybody have any links to good sites to buy from?
Old Mar 3, 2006 | 10:48 AM
Talon585's Avatar
Theres always ebay but heres a couple that i know of offhand.
www.tirerack.com
www.edgeracing.com
Old Mar 3, 2006 | 10:51 AM
sbowers's Avatar
if you are looking for rotas jlbmotorsports.com has the best deal on them
Old Feb 17, 2007 | 01:35 AM
vansterdam's Avatar
Here's the best tire calculator I've used. It lets you enter up to 5 sizes at once.
Old Feb 17, 2007 | 12:15 PM
Kommando's Avatar
Just look for the OVERALL diameter of the tire if you want to keep your speedo/odo correct. Tirerack shows the overall diameter oftires when you compare their specs. I used that to choose a different size than what they recommended when I was replacing the 185/60s the PO put on the stock 14x5.5 steelies(185/65 was stock/recommended). I wanted a 195mm width for better dry traction and to "fill out" the .5"-wider 14x6 rims I got (25.4mm = 1"). With the 185/60s, my speedo/odo readhigher than I was going too, so I went with a 195/60 tire instead of the 195/55. I run a '00 VP sedan and chose Yoko Avid H4Ss BTW. 15s or 16s would likely be a better choice aesthetically, but I was minimizing present and future tirecosts. 185/65-14 or 175/70-14 skinniesmight have been better for the recent snow though. You'll want lower profiles than that with 15s or 16s. My speedo/odo still reads a bit high, but it's closer to actual than before...and the difference in wet traction is insane. They don't do too bad in1-6" snowfor what they are...a wider-than-stock performance tire(I usually drivea Jeep w/Trxus MTswhen it's nasty out anyway). Deeper than that bottoms out the car too much for any decent traction.
