Brakes
Old Feb 28, 2007 | 07:18 PM
DuB_ManiaC's Avatar
Default Brakes
I was searching internet, and had never found any kit that replaces rear drums for disk brakes. So anyone know where i can buy some disk brake kit Front + Rear ????
Old Feb 28, 2007 | 07:22 PM
ej6buddy's Avatar
Default RE: Breaks
it's "brakes", and you should already have front disk brakes, if they need replaced, then go buy the parts from your local parts store, if you have rear drums and want rear disks, then it depends on which year civic you have, usually you replace several components from acura's counterparts
Old Mar 1, 2007 | 08:24 AM
DuB_ManiaC's Avatar
Default RE: Breaks
damn...sorry for misspell, actually I was asking about some aftermarket brakes for front and rear like Brembo or Wilwood, and they should go on 97 EX
Old Mar 1, 2007 | 01:40 PM
ej6buddy's Avatar
Default RE: Breaks
does your 97 ex come with abs? and yes, they have different brake sets ranging from just stock replacement, to performance (drilled/slotted with better pads), to all out big brake kits. if your wanting performance oriented braking, then brembo, and other good brands are a good pick. wilwood is more into big brake accessories rather than replacement. for your car, you don't need to get any big brake kits, so just look for a set of drilled/slotted, or oem replacement, and get a set of high performance brake pads, that should for a while at least.
Old Mar 1, 2007 | 04:32 PM
DuB_ManiaC's Avatar
Default RE: Breaks
mine is actually without ABS, can you give me some link for oem drums replacement kit ?
Old Mar 1, 2007 | 06:36 PM
ej6buddy's Avatar
Default RE: Breaks
Old Mar 1, 2007 | 10:55 PM
mxs's Avatar
mxs
Default RE: Breaks
ORIGINAL: DuB_ManiaC
Tire Rack has them, at least for the front
jonsaidthat
May 30, 2010 09:30 PM
ahhsimon
Jun 14, 2006 09:52 AM
faceless_civic
Nov 17, 2004 10:19 PM
aggie99
May 17, 2004 12:01 AM
NTX
May 7, 2004 11:25 PM
