brakes
Old May 13, 2005 | 07:34 AM
neon3kgt's Avatar
Default brakes
if i get the rear caliper and rotor off of a 99-00 si for my 00 civic ex can i switch it to discs? is that all i need? or does the system send diffrent pressure to the rear of a drum than disc setup?
Old May 13, 2005 | 01:07 PM
speedstream's Avatar
Old May 13, 2005 | 01:40 PM
Pete's Avatar
Default RE: brakes
i was going to do it too.......but i hear its a PAIN in the ***.
Old May 13, 2005 | 08:14 PM
Default RE: brakes
heard so to - and u would have to change the fronts cause the conversion makes the rear brakes stronger than the front
Old May 14, 2005 | 12:19 AM
sacicons's Avatar
Default RE: brakes
its not that hard to do. you need the whole rear suspension, except the shocks/springs. the entire trailing arm assembly, including the e-brake cables. then it pretty much bolts on. oh, and you can get it all from a 90-01 integra.
Old May 19, 2005 | 01:50 PM
neon3kgt's Avatar
Default RE: brakes
thanks
jonsaidthat
May 30, 2010 09:30 PM
ahhsimon
Jun 14, 2006 09:52 AM
faceless_civic
Nov 17, 2004 10:19 PM
aggie99
May 17, 2004 12:01 AM
NTX
May 7, 2004 11:25 PM
