Budget suspension mods
Old Jun 9, 2006 | 11:02 PM
pWnEdU's Avatar
Default Budget suspension mods
So far with some searching, I've only found strut bars as being a cheap suspension upgrade. I don't want to lower, raise, or otherwise dump a bunch of money into my suspension.
The theme of my car is "bread and butter", I'm sticking to I/H/E on the motor, so I want just the inexpensive basics for the suspension... if strut bars make a noticeable difference, then that's probably all I'll do.
The brakes on these cars are fine IMO for street only use, so I'll be done trying to figure out my setup once I figure this Q out.
Old Jun 9, 2006 | 11:28 PM
AgentofDarkness's Avatar
Default RE: Budget suspension mods
You could also get sway bars, its not as easy as strut bars but not as hard as lowering springs. For brakes, you can get a performance pad. Hawk makes some good brake pads. You could also try getting some slotted rotors. Some say they help brake faster and others say they don't. If you get rims, slotted rotors do look pretty good.
Old Jun 10, 2006 | 10:28 AM
pWnEdU's Avatar
Thanks for the info. I've tried slotted rotors before, they don't help with braking power, they just help with fade. IMO... I'm probably going to leave my brakes alone.
Are sway bars spendy? They won't make the car ride any rougher will they? Do you think a sway bar/strut bar combo will make a big difference? I thought these cars came with at least one sway bar, but I guess not???
I know lowering is the best option because it brings the COG down, but I just don't want to lower the car.
Old Jun 10, 2006 | 12:21 PM
Chimera02EX's Avatar
you can get a set of sway bars for about 300. Megan racing makes good strut bard and man do they make a difference, also a lower tie bar will aid nicely too. You will see a noticable reduction in body roll w/ a full set of strut bars, and even more so w/ some sways.
Suspension Techniques and Progress Tech are good sway bar companies, but do some searching and see what fits your budget.
Old Jun 10, 2006 | 03:25 PM
pWnEdU's Avatar
Based on that ebay strut bar thread, I'll be getting those, and if I think I need more after that, and I have the cashola, then I'll probably swing for some sways. Thanks.
Old Jun 10, 2006 | 04:41 PM
I think that civics only come with front sway bars and you will have to buy new control arms to use rear sway bars. I'm not sure about that, but i'm pretty sure that they don't have rear sway bars.
Old Jun 10, 2006 | 06:22 PM
neon3kgt's Avatar
civic SIs have rear anti sway bars. you can just get one from one of those. i got a quote for 100$ for the rear once from honda.
Old Jun 10, 2006 | 08:09 PM
pWnEdU's Avatar
If my civic already has a front sway bar, and mods are required to run a rear, then I probably won't mess with it and just worry about strut bars...
AtR_Bucctown
17
May 22, 2009 03:55 PM
smokingemcee
Jan 30, 2006 06:50 PM
Punter
Jan 24, 2006 04:43 AM
baker
Jan 19, 2006 02:53 PM
Forty04
Sep 29, 2005 01:36 PM
