camber kit help!!!!!
Hey I have a 88 Honda hatchback and I was planing on lowering it with some coilovers about 2 1/2". I've seen different camber kit options. Like ones with adjustable ball joints with the rear lcas and camber adjuster. I'm wanting to retain the 0 camber. Would the kit with only the upper control arm w/ajust. Ball joint, LCA, and rear camber adjuster be fine or do I need the adjustable a arm mounts too. Here's the kit I'm looking at. I was wondering if it would work fine thank you. http://www.ebay.com/itm/380642840974
unless your slaming the car on the ground a basic camber kit is all you need. im not familiar with older civics but i believe the adjustable ball joint on the the camber arm is what allows you to adjust the camber given your car uses a double wishbone suspension. the newer civic uses a macpherson strut which requires front camber bolts.
Even a factory car has camber. you don't want 0 camber all around.
Good thing is that camber doesnt destroy tires. Toe does. Get the car aligned afterwards to correct this. IMO, camber kits are for looks only. I have them and running -2* up front and -1* in the back
mountain_man
Oct 16, 2009 05:47 PM
larring1020
Dec 8, 2006 12:55 AM
