Changing Lower Control Arm Bushings
Old Jul 17, 2007 | 03:08 PM
badmafia's Avatar
Default Changing Lower Control Arm Bushings
I need a new inner and outer lower control arm bushing on the drivers side and a new outer lower control arm bushing on the passenger side (already paid to have inner changed) I was wondering if it'd be easier for me to change the control arms (bushings already installed) or to try and change just the bushings on my current control arms? I've searched google and can find nothing.
Thanks
Old Jul 17, 2007 | 04:30 PM
Default RE: Changing Lower Control Arm Bushings
just be a pimp and rock new LCAs
but seriously, it'll be about the same.. either way, you have to take the LCAs off. The only difference is you have to take the bushings out of the old ones, so I guess it's technically harder.
Old Jul 17, 2007 | 05:05 PM
badmafia's Avatar
new bushings would be $100 cheaper, thats why I was asking how hard the bushings are to change? Is a press required if the old ones are shot?
Old Jul 17, 2007 | 09:32 PM
mxs's Avatar
mxs
front or rear?
it's not THAT bad. you have to burn them out. it just takes a while and it smells...
Old Jul 17, 2007 | 09:39 PM
badmafia's Avatar
front, can I put the new metal ones in w/o a press? Can I burn them out with a propane torch?
Old Jul 17, 2007 | 09:44 PM
mxs's Avatar
mxs
I burned mine out with a propane torch, and I replaced them with Energy Suspension polyurethane bushings. I didn't need a press but I don't know what the stock ones are like.
Maximus from the 915
May 29, 2010 06:38 PM
brunborg
Jan 14, 2008 08:38 AM
tlkolrod
Dec 29, 2006 06:44 PM
sparklefrog
Jul 23, 2006 08:39 PM
gkwoodfloors
Nov 9, 2005 01:20 PM
