coilover question...
Old Sep 15, 2008 | 10:46 AM
AaaronF's Avatar
so wait... you have to use a spring compressor to get the springs off... but not to put them back on?
Old Sep 15, 2008 | 01:08 PM
yup... aftermarket springs are significantly shorter than oem springs, so you don't have to compress them to put them back on the shocks.
Old Jul 26, 2012 | 07:33 PM
aztecaa's Avatar
Where do the metal rings go? There are 4 very skinny metal rings! Which do NOT fit over the sleeve, only on the bottom end!
Old Jul 26, 2012 | 07:35 PM
aztecaa's Avatar
Oh, one more thing, are there FRONT n REAR coils when replacing with coils over sleeves kit?
I contacted the company and they said the coils are all the same.
I ended up putting those metal rings at the bottom.
I cut the bump stop down to 1 inch.
Put the thickest o-ring over the strut with Rubber tape over that wrapping it around until it was tight enough to slide the sleeve over using vasoline.
When putting these back together, you have to leave those caps off they send you in order to fit the original tops back on. Why...Because it won't fit, screw too short on strut, at least mine.
Now I just have to wait for my warranty replacement Koni's which I am upgrading to Yellow from Orange for heavier duty! Expensive, $116 ea.
And yes you need spring compressor to take off but not put on cause the they are shorter.(Mine were so weak that I didn't even use a spring compressor, only pointed it towards the ground, small pop)
So far with my old struts, very little gas pressure the ride is much stiffer but my vehicle stays up when putting things in the back. A little bouncy until I put in the new struts"I HOPE".
addiction2bass
22
Apr 26, 2008 06:06 AM
burgernuds
Sep 7, 2007 01:38 PM
nik005
Aug 18, 2007 01:09 PM
WhatsAClutch?
Feb 6, 2007 08:33 PM
ozion787
Dec 11, 2006 03:37 PM
