Coilovers and spring question?? HELP
Old Feb 8, 2006 | 11:08 AM
naucrx's Avatar
Default RE: Coilovers and spring question?? HELP
ORIGINAL: SITNLOW97
well i decided to only go about 2' drop with springs!! And yes i was talking about i heard bad things about the cheap *** sleeves coilovers!! But can i use stock struts with like a 2' drop and get a descent ride??
Okay, whew... I was gonna say, how could anyone not like coilovers?! lol If you've got the money I highly recommend them. I went from a KYB/lowering spring setup to Tein SS dampers on my EG and it was like night and day. I will never own another sport compact car without a coilover suspension.
You should be fine with a 2" drop on some springs and still have a decent ride. Just take 'er easy over speed bumps and such and your stock struts will last longer.
Old Feb 8, 2006 | 11:44 AM
SITNLOW97's Avatar
So im guessing i will still need a camber kit with like a 1.5 to 2 inch drop even if i get it aligned??
Old Feb 8, 2006 | 11:46 AM
SITNLOW97's Avatar
hey naucrx, how much did ur coilover setup cost and where did u get it?
Old Feb 8, 2006 | 12:33 PM
naucrx's Avatar
ORIGINAL: SITNLOW97
Yeah, you will definitely need a camber kit with a drop like that if you want your tires to last. Without one you can at least correct the toe with an alignment so your tires will last a little bit longer. Plan on having to flip-flop tires at least once if you skip the camber kit. My car is dropped about 1.75 inches and I've got -2 degrees camber up front and -1 in the rear after an alignment. I like the way the car handles and rides though so I think I will leave it as-is and skip the camber kit. My tires probably won't last more than 20,000 miles though, but that's all right with me.
ORIGINAL: SITNLOW97
I got the Tein SS coilovers on eBay for $400!! I spent about 3 weeks on there searching like a madman until I found them. They are used but in perfect working order. The only thing wrong with them is the green paint is coming off where they attach to the spindles. I think they were still a smoking deal though! If I remember right they run about $900 new on eBay. But IMO they are well worth $900.
Old Feb 8, 2006 | 12:38 PM
ef4life's Avatar
yeah a camber kit is always a good idea even when your not lowering your car a lot. omni power has good coilovers for like 650 dollars, tein basics start at like 750. the super streets will run 1000-1400 depending on car but are efdc compatible
Old Feb 8, 2006 | 01:42 PM
SITNLOW97's Avatar
so these coilovers ur talkin about include the strut too right?
Old Feb 8, 2006 | 01:49 PM
ef4life's Avatar
yeah full coilovers from omnipower are like 650 at http://www.passwordjdm.com/prodtype....ageHistory=cat they also have some camber stuff and aluminum lower control arms. all tein stuff is really good stuff well worth the price
Old Feb 8, 2006 | 01:54 PM
dj_ipirate's Avatar
i herd coilovers give you "rice bounce" or is that only when you put them on a stock suspention, or what?
Old Feb 8, 2006 | 01:57 PM
SITNLOW97's Avatar
The only ones i seen on that site are like 850, im i just not seeing them or what??
Old Feb 8, 2006 | 01:59 PM
SITNLOW97's Avatar
i know the coilover sleeves are bouncy as hell but the all in one coilovers are great as ive heard!!
