do bump stops really need to be cut?
Old Apr 30, 2005 | 03:20 PM
mill$civic's Avatar
Default do bump stops really need to be cut?
I got a 2000 civic and i got a pair of free brand new tein lowering springs cuz i did co-op at a performance shop,its a 1.7 drop in the front and 1.5 in the back, not to low but just noticable,anyways,i was reading the paper that comes with them and it says how much u need to cut the bump stop on different cars and it says that u have to cut mine. I was talking to the guy about it and he sead that when they put springs in, they dont cut the bump stop because it dosent do anything, he dident even no u had to cut them when i told him, what do u guys think? what is the point of cutting the bump stop?..thanks
Old Apr 30, 2005 | 09:23 PM
sacicons's Avatar
Default RE: do bump stops really need to be cut?
you need to cut them if the spring manufacturer says to. if you dont, then when you hit a bump, the shock will hit on the bumpstop, and it will fell like you have WAY to stiff of springs. they need to be shorter to give you a little more travel in your shock.
Old May 1, 2005 | 04:01 PM
mill$civic's Avatar
ok i understand that u need to cut them and why , but if u dont want your car to bounce around alot then it would be better to only cut them a bit or not at all????
Old May 1, 2005 | 08:46 PM
sacicons's Avatar
there should be some kind of guide with the springs that shows how to cut them.
Old May 2, 2005 | 01:22 PM
wannabfast's Avatar
theres a reason why theres a bumpstop.. its to stop the shock from moving too much, so it keeps it from damaging the chasis or shocks
Old May 3, 2005 | 03:30 PM
mill$civic's Avatar
ok thanks, so then, if i dont get the bump stops cut then it will just be a really ruff ride? will it wreak anything?
Mecca8383
Jun 28, 2010 08:10 PM
Partizan
Jan 25, 2007 09:13 PM
vbcamry
Dec 25, 2006 02:19 AM
Raul98
Jul 21, 2006 08:47 AM
grncivicvtec
Jan 22, 2005 08:47 AM
