dropped finally.
Old Jan 22, 2009 | 11:31 AM
  #21
civicexracer's Avatar
as far as adjusting the shocks to make them "stiffer", i'd just set them either 1 or 2 full turns up from their lowest setting. adjusting the shocks doesn't really make the car feel like its stiffer or anything like that. adjusting them allows you to control the movement of the spring according to the spring rate on certain surfaces and in motor sports, according to track layout/pavement. the Tein springs are pretty soft springs so for the best ride all around, u'd be better off having the shocks set at a fairly low dampening setting.
Old Jan 22, 2009 | 12:05 PM
  #22
when i drove mine pretty low i set the fronts to firm and i put the rear to soft. thats the best settings i could find for daily driving with it so low.
one thing i definatly want before i put my setup on my 96civic is the front extender top mounts. and ill also be modifying the splash shields and bracing behind them so i can get the most travel as i can... only thing i wont install on the 96 is the front camber arms. ill still use the rear but not the front since the lower you go the more posibility it is for the larger Aarm to hit the tower... tho i might install them later on if i decide to lift the tower a bit in that area for clearance.... just one good thing about having a cheap rebuilt civic.LOL cutting doesnt bother me to much.
Old Jan 22, 2009 | 12:13 PM
  #23
oh and another thing, never set the shocks all the way at the max and leave them there. sure way to blow them much faster..
Old Jan 22, 2009 | 01:12 PM
  #24
max at firm or soft? or both?
curious. i had mine about 1/4 of a turn from max firm and soft in the rear. not quite full both ways. but im curious...
Old Jan 22, 2009 | 04:07 PM
  #25
Overurhead360's Avatar
i think i have them 540 degrees turned. on all 4. i read in a couple places that putting them the full 720 didnt do anything more then the 540.
Old Jan 23, 2009 | 12:23 PM
  #26
1/4 turn from the max is the most you should have them at any point. i'm not so sure about from the lowest setting but i'd go 1/4 turn from there aswell.
Old Jan 23, 2009 | 12:52 PM
  #27
ej6buddy's Avatar
I run at all the way on soft. but of course, i'm running 560/336 lb. springs.
Old Jan 23, 2009 | 01:34 PM
  #28
good to know... id like to swap out my springs for stiffer ones for the lower ride height as well.
Old Jan 23, 2009 | 07:56 PM
  #29
ej6buddy's Avatar
What are you running currently (not your stockers, your gc's)
Old Jan 24, 2009 | 01:34 AM
  #30
dont remember i just know they where for daily driving i believe... i do know the front springs are a inch to short.
