eibach springs?
Old Nov 9, 2006 | 11:36 PM
ic892003's Avatar
Default eibach springs?
i found these eibach springs that will lower my ride approx 1.6 inch http://www.optionimports.com/4-174.html, these are the eibach sport line springs, are these springs good for everyday use and most important is this all i need to lower my ride or do i have to purchase something else 2 replace oem parts of my suspension, going on a 92 civic 4dr lx
Old Nov 10, 2006 | 12:29 AM
TheMoogly's Avatar
Default RE: eibach springs?
Your link didnt work but I would say be really careful because anything more than a 1.5" drop will put ALOT of strain on your shocks and they will eventually blow. Plus, you'll need to consider camber kit to adjust, a good alignment and aftermarket shocks/struts... You should wait until someone with 1.6 drop gives you a word about it. I am not sure if .1 inch makes a big difference but who knows, worth the wait, i think!
Old Nov 10, 2006 | 08:42 PM
Nail I3unny's Avatar
i agree. anything more than 1.5" drop you want to start thinking about aftermarket shocks.
also...anything of much of a significantly higher spring rate you want aftermarket shocks.
as well as ac amber kit. anything lower than 1.5-1.75 you will start having some pretty bad camber issues.
Old Nov 10, 2006 | 09:44 PM
drbyers's Avatar
go for the H&R lowering springs. they drop .75 inches and shouldn't blow up your OEM shocks.
Old Nov 10, 2006 | 10:23 PM
no....sports drop 1.5-1.75 and races drop 2-2.5
Old Nov 10, 2006 | 10:30 PM
Partizan's Avatar
yeah but the oem sports drop .75 or os
Old Nov 12, 2006 | 12:34 AM
mxs's Avatar
mxs
those springs will be fine, you don't really need anything else. You have the option of upgrading to aftermarket shocks, which you might want to replace anyway if they are the original ones that came on your car.
Ramyswar
Feb 4, 2012 05:09 PM
snosurfa7
Jun 14, 2006 04:18 PM
everglo
Nov 24, 2005 02:30 PM
eg9
Nov 10, 2005 12:43 PM
burner79
Dec 23, 2004 09:38 AM
