flat tire after wheel was hit
Old May 21, 2006 | 11:08 PM
roudan's Avatar
Default flat tire after wheel was hit
Hi, everyone
I got a car accident. Some one changed the lane very quickly on my right and hit the right front wheel of my car, leading to lose control of my car. Fortunately, I was OK. But I drived with flat right tire for a while at low speed. Although my car was tow away for fixxing, I want to know what would be damaged after driving with flat right tire, or what I need to check if they will be Ok after coming back from auto repair shop? Thanks.
Old May 22, 2006 | 02:44 PM
Dogmeat's Avatar
Default RE: flat tire after wheel was hit
Front wheel got hit hard enough to bend the rim???..
Suspension (strut mounting, tie rods), alignment, balance the wheel, doubt the brake rotor got bent, but have them check that too. Hard to tell if anything gets pushed around with out having it on a rack.
Old May 22, 2006 | 04:01 PM
roudan's Avatar
ORIGINAL: Dogmeat
Thank you very much, Dogmeat
Old May 23, 2006 | 10:14 AM
TFC_Bob's Avatar
Tire is most likely done, as soon as you run on a tire lower than 80% of rec. inflation the inner liner gets chewed up and makes the tire unusable.
dpula2
Oct 10, 2013 09:16 AM
EEPE52
Oct 10, 2010 10:57 AM
stevenCivic
15
Dec 1, 2009 03:35 PM
kinosh
12
May 27, 2007 06:18 PM
ic892003
Jan 26, 2007 06:34 AM
