Hubs and bearings
Yeah, remmy, I know replacing the axle sounds like a mother****er, but it's actually quite simple... a lot simpler than replacing the wheel bearing. Hondas are notorious for their ability to go through CV boots. But yeah, it sounds like your CV joint is shot.
1- 3/16" for the axle nut, I believe (off the top of my head)... definitely double check that though.
You may also want to find a big-*** hammer (in case the axle is rusted into the hub.) Put the axle nut on backwards until it is flush with the tip of the axle, then beat the **** out of it.
ball joint and tie rod end might give you a nice time but if you have a nice sized hammer after you unbolted the 17mm nut from both hit the knuckle part of both (takes me 1-2 hits ) might take you a couple more. just gotta know where the sweet spot is.
Ok Ive figured out the main symptom.... it makes loud pops when accelerating. Help! It has gotten worse today... its too the point where I can feel it thru the floor boards? Should I walk to work tomorrow?
it is 32mm for the spindle nut, and a big *** breaker bar never hurt
ORIGINAL: ohbiskits
all u need is i think a 17mm socket..and a big screw driver...i dont rememebr the size socket fort he spidnle nut but other than that..thats all u need
