ideas for first suspension mod
Old Jan 22, 2006 | 02:48 PM
97_nw's Avatar
Default RE: ideas for first suspension mod
yes, but you'll also sacrifice your ride qualtiy..kind of a give and take thing, you can get one, but not the other.
Old Jan 22, 2006 | 08:56 PM
Big T's Avatar
Okay. Im prolly gonna get the strut bars.
Old Feb 1, 2006 | 07:36 PM
Big T's Avatar
I've seen alot of people just have the one front upper strut tower bar. So, am I goin overboard with gettin all 4.
Old Feb 1, 2006 | 08:28 PM
Chimera02EX's Avatar
No definately not going overboard at all. The set of 4 will make a HUGE differnce. Do it up.
Old Feb 2, 2006 | 11:03 AM
skytanker2003's Avatar
ORIGINAL: Big T
I'm not really looking to lower it. Just stiffer. Plus, I'm prolly buying 16's this summer. So I don't want to lower it now if I gotta put bigger wheels on later. What mod would give me the best results in handling? I dont really want to spend over $250.
Correct me if I'm wrong, but the outside circumference of the tire doesn't change too much, it's the wheel that gets bigger, and the rubber smaller, huh? The tire'd be a little bigger than stock, of course, but not THAT much of a difference, right?
Old Feb 2, 2006 | 12:53 PM
neon3kgt's Avatar
the aspect ratio changes so that the outside circomfrince stays the same (or verry close) and you just lose rubber. this makes the vehicle handle better and ride worse. <wishes we had spell check.
Old Feb 2, 2006 | 01:54 PM
polo708's Avatar
IMO you should go with springs first, then sways... strut bars are a dime a dozen and dont do very much on stock suspension.
Old Feb 2, 2006 | 06:30 PM
Big T's Avatar
Yeah, I didn't know at the time I posted that that your tire circumference would stay the same, so ignore that.
Old Feb 3, 2006 | 11:01 PM
jwsimons's Avatar
polyuerathane bushings will tighten everything up and make a huge difference... master kit for about 130- 150? check energy suspension out
if you did this, then you would want the bars, because the force is now on the towers and not the bushing!!!!
Old Feb 3, 2006 | 11:26 PM
polo708's Avatar
and for manual trannies, motor mounts are a good way to fight wheel hop during launches.
