korbache chassis stiffener
has anyone installed the korbache (i think that is what it's called) chassis kit. if so, comments would be wicked, cuz i have little money and need reasonable results
I really liked the eBay tie bar kit I had on the Civic... until I got the MINI and started to do some real research into chassis tuning and got some real products with some real R&D behind them.
For any front wheel drive factory car your best bet is to get a larger rear sway bar. Period. It'll neutral the oversteer and reduce roll. Next thing to do is fix the toe problem that car companies build into cars for safety in corners when unexperienced people let up or hit the brakes... this is harder and requires some custom work though.
As far as the frame locks go, I'm willing to bet they do quite a bit of good if you already have larger front and rear sway bars that are dialed in.
dalifts
Sep 4, 2005 08:21 PM
adrenal
Jul 19, 2004 08:43 PM
