popping noise
Old Aug 6, 2006 | 05:46 PM
Ben's Avatar
Ben
Default popping noise
I have an 02 Si, I notice when im backing up or taking off in first if I give it a little too much gas, and let the clutch out (not popping it) it makes a loud popping noise. Has anyone ever encountered this? It feels like suspension and not the tranny but if anyone can help it'd be appreciated.
Old Aug 6, 2006 | 11:43 PM
KarTuneMan's Avatar
Default RE: popping noise
Constant velocity (CV) joint. Stick your head under to get a look at the CV boot. inspect it, holes and the clamps that hold the boot on. Debris in the boot is no good. These are normal wear items...meaning, they wear out! How many miles on the car?
Old Aug 6, 2006 | 11:58 PM
Fiirkan's Avatar
could be a ball joint, my upper one is shot to hell and it makes that noise, does it do it when you go over bumps? if so then i would get teh ball joint checked
Ben's Avatar
Ben
26000 miles. And should also add that the car doesn't do it on a regular basis, in the month and few weeks of owning it its done it twice.
Old Aug 7, 2006 | 12:43 AM
Ben's Avatar
Ben
not not when going over bumps, did it once when I was leaving a stop sign after first getting it (a little rusty on the clutch) and I reved it up a little to high and it popped when I let the clutch out, and then today backing into my driveway I was on the slope in reverse, and when I reved it up and went backwards it made the pop again....doesn't feel or sound too serious but wanting to know what it is and what to do to fix it.
celestialwolven
Feb 26, 2011 07:34 AM
96Cex
Jan 19, 2010 07:50 PM
jacksmash
Nov 3, 2009 02:35 AM
tarboroheel1
Sep 22, 2006 08:50 PM
Dezrat
Aug 5, 2006 05:55 PM
