lca trouble
Old Sep 6, 2007 | 05:33 AM
jhsplaya08's Avatar
Default lca trouble
ok, i was going to put on one of my new lcs's yesterday. got to the last bolt thats under the rotor and it will not move! this thing feels like its welded in. and i tried so hard to get it off and the socket slipped and stripped the bolt. so now im screwed i guess. anything i can do? or is it gonna have to somehow be cut off......?
[IMG]local://upfiles/3700/C691DFAE82E640739BF47E662389642B.jpg[/IMG]
Old Sep 6, 2007 | 05:39 AM
My04Civic's Avatar
Administrator
Default RE: lca trouble
lca bolts strike again
going to most likely have to be drilled out i would assume
Old Sep 6, 2007 | 06:20 AM
Strong Island's Avatar
those are B!tch to get out, i broke one of mine but i was luck and the rear disk conversion i bought had the bolts still on it so i used them but yeah your going to need to get it drilled out, either do it your self and use a easy out to unscrew it or a shop
Old Sep 6, 2007 | 09:37 AM
civicexracer's Avatar
i hate that bolt. i broke the head off mine and cutting thru it and drilling thru it was such a headache. i'd still try to get it out with a special socket for stripped bolt heads, and use a looong breaker bar. chances are tho, it is seized in there and u'll have to drill it out.
Old Sep 6, 2007 | 09:53 AM
Everyday Getaway's Avatar
That sucks man, the same thing happend to one of my LCA bolts when I was installing my rear suspension,now it creaks like crazy over every bump[:'(]
Old Sep 6, 2007 | 10:30 AM
Marty's Avatar
to me it's worth it to take it and have it taken off
Old Sep 6, 2007 | 12:20 PM
amg6975's Avatar
If you can get any torque on it, try whacking the crap out of it with a hammer (straight on the head of the bolt)then turning it. Then after that, a drill and an easy-out are your next options.
Old Sep 7, 2007 | 04:54 AM
Heat, a ****load of PB Blaster, and a long freakin breaker bar. Give it hell and maybe you'll get lucky....don't plan on it though
Old Sep 8, 2007 | 07:43 AM
jhsplaya08's Avatar
screw this guys....i havent driven my car for 2 weeks because of that coilover sleeve or whatever. the sleeve came in today and its the wrong one. im pissed and am not even worried about the lca's right now.
Old Sep 8, 2007 | 07:45 AM
riceburner700's Avatar
i would try the special strip bolt socket first
