lots of play in brakes
Old Jun 9, 2005 | 08:15 PM
90civic16's Avatar
Default lots of play in brakes
hey sometimes when i push in my brakes there is alot of play and they go down alot before engaging a bit sometimes they dont feel like theyre going to engage at all , i drive a 90 civic hatchback . anyone with info on thsi please help
Old Jun 9, 2005 | 08:44 PM
ngoti 8tor's Avatar
Default RE: lots of play in brakes
Sounds like you need some brake servicing.
If your pads are good, you may have loe brake fluid, or even air in the brake lines. The best thing to do is flush out all of your old brake fluid and put in new stuff, then "bleed" the brakes to get all the air out of the lines.
Old Jun 9, 2005 | 10:41 PM
Pete's Avatar
well said negotiator.......but first check the small stuff........make sure uve got enough brake fluid......and then id have someone pump the brakes for me so i could walk and check all 4 brakes and make sure there is no leaks.
jonsaidthat
May 30, 2010 09:30 PM
ej1md94
53
Feb 9, 2007 08:47 PM
ahhsimon
Jun 14, 2006 09:52 AM
NTX
Feb 25, 2005 07:05 PM
faceless_civic
Nov 17, 2004 10:19 PM
