Lower ball joint
Old Jun 27, 2010 | 06:26 AM
burnindesirez02's Avatar
Default Lower ball joint
What is the easiest way to remove/replace lower ball joint without a press?
Old Jun 27, 2010 | 10:24 AM
NonRicer's Avatar
BFH? haha
Old Jun 27, 2010 | 10:25 AM
hah, i dont have a BFH.
Old Jun 27, 2010 | 12:42 PM
Remove the knuckle yourself and take it to a shop to have the old ball joint pressed out and the new one pressed in.
Old Jun 27, 2010 | 03:18 PM
yes.... that lower balljoint is a PITA!!!!!! at least it was on my old 94 EG!
to take it out it had a snap ring you had to remove from the bottom and then had to drive it out with a BFH and do the reverse to put it back in. but if you dont have a table vise dont even try it! it sucks!
but if you do it yourself to make it alittle easier to install the new one then put the balljoint in ur freezer for awhile, the cold helps shrink the metal alittle and ever little bit helps when slamming a balljoint in witha hammer.lol
Old Jun 27, 2010 | 03:56 PM
StifflersMom's Avatar
Cat Fuсker
Heating up the arm where it goes also helps.
Old Jun 27, 2010 | 05:51 PM
agreed...
Old Jun 27, 2010 | 06:07 PM
You all with your awesome ideas...too bad i don't have a BFH or a torch, or a bench vise...
Old Jun 27, 2010 | 06:19 PM
a BFH.... go buy one! torch is a simple propane torch cheap, and a bench vise get a vise and bolt it to something heavy
or just take out the whole spindle/knuckle section off the car and just take it into any shop that can press it out and new one in, not sure how much they would charge tho, but just call around and ask before ya go
javon
May 22, 2008 08:56 PM
gred001
Mar 22, 2008 10:22 PM
SiX
May 2, 2007 12:20 AM
hollis
Apr 1, 2007 06:20 PM
anthony_delprete84
Aug 9, 2006 09:11 AM
