lowering springs
Old Jun 24, 2007 | 09:16 PM
jesus95's Avatar
Default lowering springs
so im looking at lowering my 95 del sol SI about an inch and a half. does anyone know if s-tech tein springs would be good for that or should i go for something else. would i need a camber with that and possibly shocks? thanks
Old Jun 24, 2007 | 09:28 PM
PhillipBurch's Avatar
Default RE: lowering springs
Well Im not sure, but Im wanting to lower my Civic with the Tein springs. I was wanting to just get the springs, but I dont know if it will make the tire tread wear down wrong if there is no camber it.
Old Jun 25, 2007 | 04:59 AM
cderalow's Avatar
for an inch and a half drop, look into the HPK setup... it's tokico hp shocks with matched springs, and lowers the car anywhere from 1.5-1.75"
as for camber, you may or may not need a camber "kit". for the most part you can get away with using washers to shim the rear out, in the front, you will probably need it
if you have camber issues, you will wear the tire unevenly, as will toe. caster will not effect tire wear, but will effect steering.
if you're changing out springs, you might as well get new shocks, as you have to take them out and apart to put the springs on anyway, and you're better off with a performance shock and a lowering spring
Old Jun 25, 2007 | 09:29 AM
jesus95's Avatar
thanks alot man. gave me ideas to think about.
Struletz
27
Apr 3, 2005 12:36 PM
motegicivic99
Aug 9, 2004 05:50 AM
motegicivic99
Aug 7, 2004 01:56 PM
Wheelbroker
Jul 15, 2004 01:25 AM
hondaholic9
Jun 19, 2004 11:41 PM
