new Coilovers?
Old Apr 3, 2011 | 11:17 AM
boreddude564's Avatar
Default new Coilovers?
I was wondering what i would NEED to change if i got new coilovers?
Thanks.
Old Apr 3, 2011 | 11:36 AM
Shandles's Avatar
coilovers usually have the shock-part included. Its all one piece, if I'm not mistaken.
one problem you might run into is that the bolt on your lower control arms in the rear will be seized. Many people just opt to completely replace the rear lower control arm with new ones. Function 7 makes a good reliable set that will last a long time, but they're more expensive than others...
Old Apr 3, 2011 | 12:44 PM
civicexracer's Avatar
It depends on what coilovers you get. Some come with everything and you pretty much just install it as is. Some you have to use some of the OE parts. What have you been looking at?
Old Apr 3, 2011 | 03:55 PM
Old Apr 3, 2011 | 06:17 PM
Originally Posted by boreddude564
Those are not "coilovers" in the sense of how people use that term. Gerenally when people talk about coilovers, they mean an adjustable suspension(ride height and also adjustable shocks). The Tokico HPK is simply a shock and spring set. This setup is not adjustable in any way.
Regardless, you do not need to purchase anything new when you buy this kit. You will however need to reuse the bumpstop, dustboot(not necessary though), and the tophats(including all the little hardware pieces incorpoated within it). I would suggest with the Tokico suspension to cut your original bump stops in half before installing. This allows your shocks to have enough travel under hard compression.
Old Apr 3, 2011 | 06:22 PM
Shandles's Avatar
those aren't coilovers...
Old Apr 3, 2011 | 07:18 PM
I know they arent coilovers. I was also thinking the skunk 2 pro-s but they are a bit more and I'm not really gonna autocross all that much.
arcmt33
Nov 20, 2009 02:34 PM
civicowner2001
Aug 10, 2005 07:05 PM
civic96RB
Jul 6, 2005 01:38 PM
FoolishProdigy
May 1, 2004 08:52 PM
