newbie question
Old Sep 11, 2006 | 12:06 PM
vx92's Avatar
Default newbie question
Thought I would try this as a source of help. I have a 92 civic VX with power brakes. Having a problem where the brake pedal goes to the floor once I start the car. The car still stops but the pedal travel is alittle troubling. I have replaced the master cylinder, bleed the brakes and checked the pads for wear. They look fine. The rear brakes appear to be adjusted out fine as there is a slight drag on the drums when I rotate them.
Would anyone have a suggestion on what else might be the problem?
Thanks in advance
Old Sep 18, 2006 | 07:26 PM
Greoby73's Avatar
Default RE: newbie question
could be proportioning valve. all 4 brake lines run to it out of the master cyl.
Old Sep 18, 2006 | 07:32 PM
StifflersMom's Avatar
Cat Fuсker
did you bench-bleed the master cylinder? Were the brakes fine before you replaced the master cylinder?
Old Sep 18, 2006 | 11:05 PM
riceburner700's Avatar
have you tryed adjusting the clutch pedal play?
Ghosty
Nov 11, 2010 07:22 AM
93 Civ Lx
Jun 26, 2005 11:43 PM
weedhopper42
Jun 15, 2005 04:58 PM
wickedx
Feb 18, 2005 03:14 PM
