newbie question
Old Sep 7, 2005 | 08:17 AM
phatkahuna's Avatar
Default newbie question
i'm looking on buying rims off ebay,but not sure if they fit my 2002 civic sedan. could someone explain the 4x100 stuff for me.even better how about telling me what exactly i need.all i know is i have 4 bolts holding on my factory wheels.any help is greatly appreciated.
Old Sep 7, 2005 | 08:57 AM
Chimera02EX's Avatar
Default RE: newbie question
you want 4x100 bolt pattern and depending on the size you get will depend on the offset but normally you shouldn't have to worry to much about that the larger the wheel they accomodate for the offset.
What the 4x100 means is, 4 bolts 100mm diameter, if you drew a circle that crossed through the center of all 4 bolts the diameter of that circle would be 100mm. A normal offset for 16" rims would be around 40-42 and for 17" a bit lower say in the range of 38-40. If I'm wrong please someone correct me, but I'm sure I'm close.
Old Sep 14, 2005 | 08:02 PM
TorGa3iGhT's Avatar
yeah, u will want 4x100 bolt pattern. the other popular bolt patterns available are 4x114, 5x100 and 5x114. Older accords I believe use the 4x114 as well as other cars. You dont want to get the wrong bolt pattern, because you wont be able to fit the wheel on there correctly.
If you are wondering the difference between the first number, the 5 stands for 5 lug, the 4 in this case is 4 lug, meaning there are 4 holes in the rim. Civics use 4 lug.
Old Sep 14, 2005 | 09:08 PM
ngoti 8tor's Avatar
What diameter of wheel are you thinking of getting? IMO, 16" are the all around best......good looks, good performance, and still a comfortable ride.
Old Sep 15, 2005 | 01:13 PM
ORIGINAL: ngoti8tor
I'll second that!
Ghosty
Nov 11, 2010 07:22 AM
93 Civ Lx
Jun 26, 2005 11:43 PM
weedhopper42
Jun 15, 2005 04:58 PM
wickedx
Feb 18, 2005 03:14 PM
