News Pads Squeaking Problem
I changed my old front brake pads about 2 weeks ago. The driver side is fine and hasn't made a noise. The passenger side however at first was squeaking only while reversing out of parking spots (with wheel turned either way). I disasembled it and cleaned all the parts and greased the retainer clips, back of the pad, and around the seal and caliper. Put it back together and it didn't fix the problem and just 3 days ago the brake has started squeaking almost constantly (even without pressing the brake pedal). Seems to start squeaking if I take a hard turn and it deffinetely is the brake that is squeaking. What else can I try before I have to pay a mechanic?
95 CX
it has 4 disc brake conversion from a Del Sol (Iwrote down the year somewhere, 93 I think).
I know the outside pad has the wear indicator at the top, im sure the inner pad is the same but I will check.
Only the inside pad should have a wear indicator, and it should be pointing upward. You may have mistakenly installed both pads with an indicator on one side. If so, the other side has no pad with a wear indicator.
Both pads are the same, I have no idea what the wear indicator is supposed to look like. I thought it was the depressed line in the middle of the pad? There is dirt/little pieces of graval getting stuck on the backing plates and around the rubber thats around the piston, is this causing the squeaking and how can I fix this?
Your best bet may be to install some factory or pads labeled as QUIET.
